supercharger?
Old Sep 23, 2002 | 09:27 PM
stover007's Avatar
stover007
supercharger?
do you have to run 92octane if you get a supercharger on a 351w?
Old Sep 23, 2002 | 11:23 PM
MustangGT221's Avatar
MustangGT221
supercharger?
Yup.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Thats it for now, saving for a stang. Check out my Gallery for a look-see.
Justin
Old Sep 24, 2002 | 11:00 AM
rabidranger's Avatar
rabidranger
supercharger?
Any NON naturally aspirated (read : BOOSTED) engine needs higher octane fuel to run. Usually 93 is the min to be safe. Anything running greater than 8 psi of boost should have 95 plus. This gets into the racing fuel range, which is why many aftermarket screw and turbo kits offer 7 psi or so. This prevents pre-ignition and detonation from destroying your pistons.
Old Sep 24, 2002 | 01:28 PM
HotWhlz85's Avatar
HotWhlz85
supercharger?
Old Sep 24, 2002 | 08:55 PM
MustangGT221
supercharger?
You can retard the typing, or use the MSD boost retard unit, that automatically advances/retards the timing with boost to prevent damage. With that, I don't think you need 95+ octane. You just have to have the timing right, and have 93 octane as insureance.
Justin
