Sponsored by: Real Truck
Ball joint thread repair
Old Jul 2, 2007 | 07:36 PM
Dlinzy's Avatar
Dlinzy
Anyone recommend a solution to an 05 personal Fubar of the year?
Was installing DR's 2.5" leveling kit and on the final ball joint where you seat the Cam adj. the joint would spin after the nut got to the cotter pin hole.
Backing it off was almost as difficult until i hammered the cam in deeper as DR's tech suggested.
now i see the threads are hosed moreso on the nut, so i'll get 1 tomorrow and try that first.
I'm really hoping there is a DIE etc. that can be threaded to repair the threads and then try a brand new nut.
Any thoughts?
D
Old Jul 2, 2007 | 08:44 PM
Racerguy's Avatar
Racerguy
Unless there's not much left of the threads you might be able to clean them up with a thread file. Finding one of those will probably be a lot easier than trying to find a die.
For an example take a look at http://buy1.snapon.com/catalog/item....re&dir=catalog
Old Jul 3, 2007 | 01:39 PM
harald's Avatar
harald
You can buy a thread file at Home Depot.
Old Jul 3, 2007 | 02:02 PM
redford's Avatar
redford
FTE Leadership Emeritus
On the nut, just replace it. It's buggered up, you may or may not be able to repair it with a tap (that you don't own anyway) so why bother?
Old Jul 3, 2007 | 11:31 PM
miker67's Avatar
miker67
Regarding the joint spinning, place jack under the knuckle and jack up until the weight of that corner of the vehicle is supported by the knuckle, just like it would be if it had a tire on it. Don't jack it up too high, just enough so the axle comes off the safety stands. That way, if the jack gives it wont drop far. Now, take a hammer and give a couple loving taps to the side of the housing where the joints go in, also not to hard. Just do it hard enough to seat the joints. Take a socket or pipe and use that to beat the adjuster down into its seat. Everything should be snug in their tapers now and it should be a lot easier to tighten the nut once the threads are repaired, provided the dings are cleaned up enough. If there is extra resistance because of threads that are a little out of whack, even with the best of conditions you may not get that joint to tighten. A side benefit to doing it this way is that it seems torquing things under load may help a bit preventing what some people have described as "stiff" joints after installation.
I don't know about home depot, but I know for a fact that NAPA and O'reilly's sell thread files. They are lifesavers.
bfink
1983 - 2012 Ranger & B-Series
Jun 26, 2016 02:26 PM
Ratdog
Mar 24, 2013 10:59 PM
Blueheart
Dec 22, 2011 06:41 PM
gappy
Jun 26, 2007 06:33 AM
88DesertBronco
1978 - 1996 Big Bronco
Oct 13, 2004 10:30 AM
