HELP! (I told you)
Old Jul 2, 2007 | 07:13 PM
tndiesel's Avatar
tndiesel
HELP! (I told you)
O.K. so I have my new battery cables. MY big positive and two negative ones. I have connected positive to starter fine. I connected my driver's side negative to the block and it has that little wire that comes out from the end that connects on the battery (you know the one that is about 1/3 as long as the big cable and less than half the width--I don't know what it's called). Well on the other negative cable that same little wire is coming out from the other end where I connect to the block. Is that right? Maybe I have become confused and can't remember how to reconnect everything back in order. It doesn't seem to have a place to connect to. Maybe the guy who made it messed up?
Need help quick please, I really want to have this thing up and running by tomorrow.
Old Jul 2, 2007 | 07:29 PM
Cuda_jim's Avatar
Cuda_jim
Both big negative connections go to the block, the little negative connection goes to, oh heck here's a picture:
Old Jul 2, 2007 | 07:33 PM
tndiesel's Avatar
tndiesel
Originally Posted by Cuda_jim
Both big negative connections go to the block, the little negative connection goes to the body IIRC.
Thanks Jim and forgive me I went back out there and found it. Maybe I need more patience not smarts!
zam
Aftermarket Products
Oct 4, 2016 07:33 PM
sjbrink
59
May 20, 2016 02:54 PM
gman97005
Aug 15, 2015 04:14 PM
rct2000
Jun 17, 2015 11:09 AM
old broke prospector
Aug 9, 2013 12:26 PM
