Ford Dealer Stole My $820 Harley Special Edition Spare Tire And Rim
#76
Originally Posted by Vijay
posting to subscribe....
any word on the video of the place? that sounds like it has the most potential to figure this whole deal out if it shows anything.
#78
Here's a possible way to tie the spare tire to what may have come from a dealers inventory. It's possible that the same info that is on the tire sticker may match another new tire in the dealers stock. If so, what would the odds the tire DIDN'T come from the dealers stock?
#79
on
Good call Bill. I hope he don't get the stock spare dirty till he gets the coppers to check it out. I figured you would come up with something do do with the stickers Bill. But I never thought of anything that easy.
#80
If the spare came on the truck from the factory, the DOT production numbers should all be the same, including the spare. Look around the lot at employees trucks. Find one with Harley wheels that don't belong on a non Harley truck, then compare the DOT numbers to yours.
Engrave your DL # on the back of the rest of your wheels next time you take them off.
#81
Call ford for copy of invoice
Originally Posted by kc10ken
No. The salesman is no longer at this dealer. The truck was a special order by another customer at another dealer 3 years ago. I guess the customer who special ordered it backed out of the deal and the other dealership got stuck with it on their lot. I CAN find out who the original dealer was, contact THEM and see if they still have any paperwork on it.
Good idea, thanks!
Good idea, thanks!
Headviking
#82
Originally Posted by Headviking
I forget the number, but if you call Ford they will send you a copy of all standard and options that the truck came with (built list). If the truck was ordered and the option was installed at the factory, it will be on that list.
Headviking
Headviking
#83
Originally Posted by redford
I'm sorry, but why does he have to prove to you that his truck came with an HD wheel for a spare?
What difference does it make whether it came from the facory or was dealer installed?
#84
Originally Posted by krewat
Or, did the spare rim show up on one of your truck's four corners ? Is one REALLY REALLY SHINY compared to the rest?
I'm thinking they screwed up a rim and shuffled the spare rim into the running gear.
My expensive spare is gone and a standard Ford factory stock spare was put back in it's place. I'm out over $820 worth of Harley rim and 18" tire.
It happened while at the dealer...plain and simple. I'm not backing down on this either.
#85
Originally Posted by bbender85
under the number of pages at the top of the thread is "thread tools" ... click it and "subscribe" shows up.
#86
The dealers service manager told me that every part on the truck has a serial number/zebra code sticker and can be traced. Using that logic, I told him GREAT, then take the bar code sticker off the stock spare that's in my wheel well NOW, scan it, do whatever you need to do and find out where this stock factory ford spare came from and who's vehicle it was originally installed on.
He made no attempt to do this or even agree with me that it could be traced in this fashion....which leads me to believe he KNOWS he has a thief in his employ and could care less or is trying to cover up.
#87
Originally Posted by WishIhada7.3
I dont understand the problem?? he said he had one and has a Invoice slip from the dealer stating it came equipped with one...he also is 100% sure of this because obviously he locked it up his self...so he has nothing else to prove he has everything he needs correct???
I have the original window sticker copy and in the options column it clearly shows an EXTRA Harley rim and tire.
#89
Originally Posted by RACERX7775
yeah, each tire has numbers on it to tell the production date. you can tell if the 16" spare has a production date of 2006 and the truck is 5 years old. that would tell you if the tire was switched. i doubt it if the 16" tire was 5 years old. they dont leave tires laying around that long.
When I get home tonight I will look underneath the truck and see if the swapped ford factory spare has a production date on it!
Thanks!
#90
THAT was one of my first suggestions.
The dealers service manager told me that every part on the truck has a serial number/zebra code sticker and can be traced.>> CORRECT Using that logic, I told him GREAT, then take the bar code sticker off the stock spare that's in my wheel well NOW, scan it, do whatever you need to do and find out where this stock factory ford spare came from and who's vehicle it was originally installed on.
