Ask the Ford guy.......
Old Jul 1, 2007 | 10:25 PM
RA051126's Avatar
RA051126
Banned
Thumbs up Ask the Ford guy.......
hi! my names matt,I am an ex Ford mechanic and speacialized in 61- 79 ford trucks and broncos. I would be happy to answer tech questions or troubleshooting problems...Feel free to write me here or at my home email ldhawkins@yahoo.com Keep on truckin!
Old Jul 2, 2007 | 07:03 AM
cujo8's Avatar
cujo8
Oldhawkins, it's great to have you on board with FTE! I have a question for you.....
I am doing a frame-off restoration of my 77 F150 2wd truck and I am adding a few power adders to my 302 engine during the process. I replaced the 2bbl carb and intake with 4bbl Holly carb and a Weiand dual-plane aluminum intake manifold. My question is what part of the carb linkage do I attach the tranny kick-down rod? Is there a way to check if the kick-down is engaging correctly or is properly adjusted, since I changed the location slightly to where it was originally attached?
Old Jul 2, 2007 | 08:05 AM
RA051126's Avatar
RA051126
Banned
The kick down linkage on these trucks attached to the throttle linkage via special bracket on the right side of the carb,now they make adaptors and such for things as this to bolt up to certain carbs, when u start modifying stuff to "make it work" is where u run into headaches...The kickdown linkage must be in line with the throttle linkage and be free to rotate on its axis and must not bind or interfere with hoses ,wiring ect..
if memory serves me, the end of the kickdown linkage has a threaded adjustment....
Old Jul 2, 2007 | 01:12 PM
X36's Avatar
X36
Welcome Oldhawkins/Nice to have ya
Old Jul 2, 2007 | 01:16 PM
Mil1ion's Avatar
Mil1ion
Matt, I can't believe you did this..In fact I'm shocked
Believe it or not there are many of us that specialize in these trucks...BUT .
we answer questions online at FTE.
We question other people's info all the time and that why INFO should stay on the site.
Why are you wanting to take people away from the site by offering your e-mail address and have people ask you privately ?
ALL Tech info should BE and STAY on FTE ..not taken away to e-mail.
That's what this site is for.
I practically refuse to answer privately because all info should be shared
here
Old Jul 2, 2007 | 01:26 PM
Mil1ion's Avatar
Mil1ion
Kickdown linkage
http://i69.photobucket.com/albums/i7...inkagecarb.jpg
Old Jul 2, 2007 | 03:12 PM
RA051126's Avatar
RA051126
Banned
Dennis, Im not trying to take away from the forum at all,if u will note, i said i would be happy to answer questions here, But i am also available at my home email to chat at a safe and more personal level as well. No offence!
Old Jul 2, 2007 | 05:53 PM
YoungMT Hick's Avatar
YoungMT Hick
brake lights? trun signals work. flashers work. pedal lights work but they will not be on when i pull the light switch. rear side markers the same deal what is wrong
Old Jul 2, 2007 | 08:31 PM
cujo8's Avatar
cujo8
Thanks for the picture Mil1ion! How's that old saying go...."A picture is worth a Mil1ion words" or something like that :-)
Old Jul 2, 2007 | 09:26 PM
Dustin1690's Avatar
Dustin1690
Good to have yeah a board its good to see more people join especially the people who are mechanics and stuff
Old Jul 2, 2007 | 09:58 PM
Mil1ion's Avatar
Mil1ion
Okay Matt,
Normally people just post their questions.
There is no need for anyone to ask for them *wink*
We are already here to help ..cause..that's what we do .
Old Jul 3, 2007 | 10:09 AM
RA051126's Avatar
RA051126
Banned
Smile lighting issue
U definately have a wiring issue,unfortunately this is hard to diagnose exactly but i would start by checking the simple things first,ie.. check all the light bulbs that none are burned out, check the wiring to each light and make sure the right wire goes to the right place, u can trouble shoot with a test light and a buddy. check for wiring splices from previous wiring problems. check also the wiring at the switch..very likely the switch could be bad or could have a bad ground...I know it sounds like a lot but u have to start somewhere right? m
Old Aug 30, 2007 | 11:12 AM
offroadinloden's Avatar
offroadinloden
I just had my tranny rebuilt and put back in but thats as far as it made it at that shop! Can you help me get it to go through the gears right.....AT C6 77-f150 4x4
Old Aug 30, 2007 | 01:01 PM
Mil1ion's Avatar
Mil1ion
Maybe check out the Drive train forum... that's where Transmission specialist's hang out
Old Aug 30, 2007 | 03:36 PM
offroadinloden
thanks
