F-150 cooling system question
Old Jul 1, 2007 | 09:22 PM
N8N's Avatar
N8N
Hi all,
below is a copy of a post to alt.trucks.ford, now with click-poppy picture goodness.
I took my "new' truck to its first job yesterday, helping a friend
clean out a guy's stash of old car parts. No problems at all until I
got to my first stop, when I shut the truck down it puked coolant
everywhere. Still never got above the "O" in "NORMAL" on the temp
gauge for the remainder of the trip. This AM bottle was empty. I
pulled rad cap and coolant level was just slightly down from the neck
of the bottle. I noticed that there are two hoses connected below the
rad cap, one to the bottle and one to a tee in what looks like a
heater hose. The tee looks factory as the hose connections are
crimped. I noticed that the hose going to the bottle was connected to
the fitting below the sealing surface for the rad cap and the one
going to the tee was above. It seems to me that this is backwards and
the system would never pressurize in that condition; my gut tells me
that I should just swap the hoses, refill with coolant and see what
happens. Is this correct?
Truck is '93 F-150, 300, E4OD, extended cab 2WD.
Here's some pics:
http://members.***.net/njnagel2/Ford.../hosepics.html
thanks!
nate
Old Jul 1, 2007 | 09:32 PM
netscaner's Avatar
netscaner
I would definately swap them.
Old Jul 1, 2007 | 10:02 PM
Mr. M's Avatar
Mr. M
when you get this coolant issue figured out, you will be content with your purchase. I'm assuming the compression was competent in all cylinders. If so...the 300I6 is a great motor!
My first vehicle was a 300I6 and my father bought it back from me...and he still drives it to work everyday. It has 275K and still pulls hard.
Old Jul 2, 2007 | 12:48 PM
N8N's Avatar
N8N
Compression test... not for what I paid for the truck. This is a cheap, used beater truck - only reason the pressure test was done was because it was low on coolant when I went to look at it and I suggested to the owner he should have it done. would have been kind of insulting to nitpick it for what I paid for it unless there was an evident issue (rough running or mayonnaise)
based on the comments I have received here and on Usenet i'll just swap the hoses and hope for the best. I hope it will be OK... someone suggested that someone may have used the hose fittings for the pressure test instead of using a cap adapter, I never thought of that but if that is the case I am probably OK.
thanks again
nate
Old Jul 3, 2007 | 03:21 PM
N8N's Avatar
N8N
Just thought I would follow up... swapped hoses last night but I only had one new mini clamp so I put it on the lower fitting. The hose to the overflow bottle was a little loose so I put a zip tie on it to cinch it up. Drove truck to a job site this AM near my house just to see if it would puke, well it did a little bit but it was around my zip tie and the amount of coolant loss was minimal. Did not notice any white smoke. So I'm going to give this a conditional thumbs up for now... will grab another mini clamp and keep an eye on coolant level and oil condition. thanks for the advice guys
nate
Old Jul 3, 2007 | 09:09 PM
Mr. M's Avatar
Mr. M
nate
Glad to hear this was of assistance. Good luck and happy torquin' with your 300 I6!
