Sponsored by: Real Truck
lift question
Old Jul 1, 2007 | 08:07 PM
unluckylow's Avatar
unluckylow
lift question
I spent hours on the internet looking for a simple shackle lift for my truck. I have a 4'' supelift suspension lift on the truck now but I would like to lift it another 1''to 1.5'' with shackels and cant find them. Any help would be great.
Old Jul 1, 2007 | 09:35 PM
75F350's Avatar
75F350
I believe that 2.5" hanger kits are as little a lift as one can get. (complete hanger kit)
You are not considering just adding a longer shackle are you? Not a very good idea. This will only lift one end of the spring away from the frame, so it would require a very long shackle to obtain the desired lift.
Plus, you are going to change the steering geometry. The caster will be way off, and will be pretty slow to steer. Not to mention, the front driveline angle will be increased, and cause binding.
If you decide to add the hanger kit, you will also need another trac bar relocation bracket to lower the trac bar. It will be shorter, and require modification (unless you have a bracket with two holes, and you are using the upper one now.
Depending on whether or not you are using a sway bar, the links are going to be very short after the lift, and may not even reach.
The drive shaft is going to be fairly short after additional lift. Getting close to the end of the splines during suspension cycles.
Shocks might fall a bit short too.
Old Jul 1, 2007 | 10:06 PM
bbender85's Avatar
bbender85
i have a 4" kit and added a 1.5" Warrior lift shackle in the front as well. it's 3" longer than the factory shackle, but you get 1.5" out of it.
i have had no problems whatsoever. steering is fine, caster is in spec, nothing is bound.
http://www.jackit.com/store/supercart.cgi?s=wrr151
http://www.tellico4x4.com/product_in...ducts_id/22333
Old Jul 1, 2007 | 10:12 PM
Nikolai's Avatar
Nikolai
You could bolt in the zero rate add-a-leaf. 1" for around $100.
