propane dual fuel system for carbed engine
Old 06-25-2007, 10:43 PM
sc00ter's Avatar
sc00ter
sc00ter is offline
I;m having a hard time finding info on setting up a propane system for my truck. It's a 73 f100, 360. I want to keep the gasoline fuel system. I know that there are lots of dual fuel setups out there, I just can't find any info on them. Can anyone point me toward some books or links where I can get more info?
Old 06-26-2007, 07:27 AM
gasman6674's Avatar
gasman6674
gasman6674 is offline
Get either a CA300-70 or a CA425M Mixer (And adaptors)from IMPCO They will work fairly well on or engine, I recommend the CA300 as it makes dual fuel easier. You will Need either a IMPCO Model E or a Century M6 Vaporiser, 2384B filter fuelock for LP, a gasoline lockoff and I would recomend a Dual Curve from Autoronics. There are some hoses and switches you need also and of course a tank which you might find used.
Contact your local LP dealer he should be able to order anything you need.
I sell the equipment but I cannot sell it retail you must work thru a dealer.
Any questions please give me a shout.
800-241-1971
Regards
Old 07-02-2007, 10:00 PM
sc00ter's Avatar
sc00ter
sc00ter is offline
Looks like the Impco 425 mounts in place of a gasoline carb- Is it normally mounted differently in dual fuel setups, or can a mixer be mounted above the gas carb in a tall air filter?
Old 07-03-2007, 06:55 AM
gasman6674's Avatar
gasman6674
The 425 can be mounted on a throttle body for dedicated LP. for dual fuel its usally mounted on an adaptor that offsets it sideways on top of the existing card, then a filter is installed on top of the 425 horizontally
Regards
cchandler4704
1997 - 2003 F150
10-01-2012 07:29 PM
Looking Up
07-20-2009 11:19 PM
bareaneye
04-07-2008 08:01 AM
mrwolf
Alternative Fuels, Hybrids & Mileage
10-22-2007 10:51 AM
powerstroke6ltr
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-05-2006 06:11 PM
Quick Reply: propane dual fuel system for carbed engine
