surface prep
Old Jul 1, 2007 | 06:01 PM
56panelford's Avatar
56panelford
surface prep
Just finished sand blasting the inside of my panel , the sand I used was fairly fine but after reusing it a few times, it has the consistancy of baking soda. Things are clean as a whistle but was wondering if there is enough tooth for the primer to adhere to, the finish is rather smooth.
John
Old Jul 1, 2007 | 08:02 PM
WALFORD'S 56's Avatar
WALFORD'S 56
I generally sand the metal before epoxy primer-gives it an edge,and takes the grit away. It should come out fine. Bill
