Worth it to fix AC?
Did you put a can of oil in it too? You should.
I wouldnt worry about the compressor. From what you are saying, it is probably working.
If you have a freon leak, you will see some oily residue at the connection or part that is leaking. That oil is refrigerent oil.
I converted my '83 to 134 year before last. First thing I did was pull a vacuum and let it sit for an hour or so with the vacuum. I had no leaks, as the vacuum gauge never moved during the hour.
The only bad thing that happened was that after I put the single can of oil in the system, my helper came back and added another full can of oil. Therefore, it could get colder than it does, but it does just fine for heat in the Western NC mountains
You might need to bite the bullet and start over with a vacuum.
Good luck!!
78Sharpshooter:
You are blind without knowing the high side pressure. If you want to fix the system, you need access to a manifold gauge set, a vacuum pump, spring lock fitting tools and a proper can tap. With 3 cans of refrigerant in the system, it shouldn't cycle. This"could" be a blockage in the system, but your high side pressure would be skyrocketing. You really need both pressures to have a clue what's going on. You can rent most of the tools from many parts stores.
As a DIY project, you could replace every component under the hood for $300-400. The actual repair shouldn't cost that much unless the compressor has grenaded (worst case).
You are going to need (at least):
-accumulator
-orifice tube
-O-ring kit to reseal all of the fittings
-solvent for flushing (lacquer thinner works well)
-Lots of compressed air and a blow gun
-refrigerant
- 16 ounces of ester oil (8 for the system, 8 to flush the compressor)
- Quality STEEL retrofit fittings. The aluminum fittings from that Death Kit are very poor quality and usually leak.
At this age, the compressor seals probably leak. Look for oily dirt on the clutch hub and oil stains on the bottom of the compressor body. A used one is a real crapshoot (bad idea). So are the cheap remans sold at chain stores like AutoZone. www.ackits.com has a NEW, good quality compressor (FS-6) for $199.
Right now, you have an unknown amount of refrigerant in the system, along with an unknown amount of 2 oils mixed running around in there. You need to have the system recovered and then inspect the orifice tube. This will usually tell you the extent of the repair.
As for being worth it, some folks don't believe $50 to fix an AC system is worth it on any car, some will spend $1000 on a beater for working AC. It's all about what it's worth to you.
To get an idea of what's involved, check out the forum at www.autoacforum.com It's sponsored by ackits.com.
