light names
Old Jul 1, 2007 | 03:32 PM
walt92's Avatar
walt92
light names
http://www.automedia.com/NewCarBuyer...0Reg_ext_1.jpg
what are the names of those lights on top of the windshield? i want to do it to my truck. thanks
Old Jul 1, 2007 | 03:48 PM
warthog5's Avatar
warthog5
Clearance Light's or Clearance Marker Lights
Old Jul 3, 2007 | 06:09 PM
walt92's Avatar
walt92
http://parts-worldllc.com/index.php?...2ce3ff3e9b3fb2
is that everything i need to install the lights myself?
Old Jul 3, 2007 | 06:21 PM
shooter05's Avatar
shooter05
looks like it. other than punchin holes in the cab. I always liked the looks of them too.
Old Jul 3, 2007 | 06:28 PM
lostin90s's Avatar
lostin90s
I put them on my last truck . Not to bad other than figuring out where to put if want stock look and feeding wire down window post isn't bad.
Good luck
Old Jul 3, 2007 | 06:29 PM
warthog5's Avatar
warthog5
Yes it is.
If I was wanting them I would get them that were LED's.
The switch allows the Hi-Five® lights to be operated independent of the headlights. You can flash them just like a big rig.
I would pickup power from the headlight switch. Then go to the ON/OFF switch.
What this would do is allow the lights to come on with the headlights and it you want to flash them, use the ON/OFF switch to Make & Break the circuit to them.
On another note. I'm not a fan of the Scotchlock connectors.
Here's a example:
http://www.anythingtruck.com/Merchan..._Code=689-69YS
I have had real good luck with the products made by Optronics. I use them on boat trailers.
http://shop.easternmarine.com/index....categoryID=285
Old Jul 3, 2007 | 06:42 PM
hogdogs's Avatar
hogdogs
I really like the marker lights... and a visor... and air horns... and 4 inch stacks too!!!
Brent
