Hey all. Just wanted to let everyone know that replacing the hub assembly isn't to difficult. The most time consuming part was transferring the four studs from the old hub to the new hub. I just double nutted the stud and drenched it with WD-40 and they came out pretty easily. My dad is working on taking the old one apart to see if it is possible to just change the bearings. I'll keep you posted.
I just did my wheel bearing yesteday on my 99 F350 and it didnt come with the studs. They are cheap though so i just bought new ones. its only 16 bucks for a new set. the part number is F81Z1107AA.
where did you get the new hub that it didnt come with them. even the cheapos from pep boys came with them.. hmmmm..... well, when i replace the other side on mine when it goes bad, if it doesnt come with the studs, i know the part ##. thanks..
mine is straight from the ford dealership my brother works at. I was suprised it didnt come with them or they didnt atleast suggest I order the studs with the bearing.
When I replaced mine, I priced NAPA (w/studs) but it only had a 12 month warranty. How did you get a lifetime warranty?
No clue.... I heard through this forum that they gave it with their F250 hubs...and I got it... that was about a year ago maybe? Mine has the wire ABS sensor in the front (they sold one with and without) I don't know if that makes a difference or not.
I got mine at Car Quest (no studs)$350 EACH.Lifetime warrenty
Ouch! I got mine at a place called Berrodin Auto parts locally. $217. NAPA wanted almost $600 (retail). Ford was a little over $400. Later hub, no mounting studs, ABS wires tied up out of the way. Non-ABS hub was $70 more. Go figure.
Got my Napa one for like 300 well worth it for the lifetime warranty
I paid right around 325 form the dealership. with the ABS wire which worked out great because my other wire was ripped in half so I just swapped it over and now my ABS light turned off. I didnt ask about a warrenty though. I'll have to look into that. I called two NAPA's and one said 420 and one said 488 so i went with the ford one since I knew for sure it would be the right one and for less money.
EDIT: I also forgot to mention mine was for an early production 1999 F350 which is somehow different then F350's built after march 2nd of 1999. I never did find out the difference.
I believe I know why they only are doing a 1 yr deal on the warranty. They were giving me a discount based on me working for a large utility. The account they used was a fleet account, therefore probably a commercial use warranty. It reduce the price from list $675 to $316 w/ studs and abs. Ford wanted $380 which was not bad.
I ended up having a local shop do the work for the part of $320 and $100 labor and it was done in 2 hours (charge 1.9 hrs labor vs Ford 2.5 hrs). So anyone living in Citrus County, FL., PM me and I will give you the shop's name. Hard to beat cussing and sweating for $100.
With all this being said, I bet I have the lifetime warranty as they got the part from NAPA, I followup on it.
