Speedo correction question
Old Jul 2, 2007 | 04:05 PM
jeffisjacked's Avatar
jeffisjacked
thanks, i just called them...88 dollars! a full hour of labor my ***... i just figured that with my stock tires, to go 70 mph, my speedometer will pretty much have to read 75 mph...good enough for govt work, good enough for me.
Old Jul 4, 2007 | 03:20 PM
Big Daddy 18C's Avatar
Big Daddy 18C
*MEMORY LANE ALERT*
I got pulled over doing 86 in a 55 when the speedo indicated 65 with 33" tires. I had to get the speedo checked, and at something like 35mph it was 7mph off. So I figured the percentage, went to court, and they shut the door on my percentage variation argument. I guess a law degree and years of "experience" count for more than empirical proof.
ANYWAY, I did the cypherins and gizintas and came up with a 20% offset (or so) and learned what each speed indicated actually equated to in real road speed.
[all the numbers above are estimates only as this happened in 1991 and my memory is only certified to 2 minutes]
Old Jul 4, 2007 | 05:22 PM
jeffisjacked
well, im basing that off the website listed above..
Old Jul 4, 2007 | 06:09 PM
puppypower's Avatar
puppypower
I have a 2007 F150 with larger aftermarket wheels and tires on the truck, however I want to revert back to my stock wheel/tire combo when I tow my car home. I know I can buy one of those 500 dollar power programmers to correct my speedo, but there has to be a cheaper way of doing this, anyone have any good info?
How did you correct your speedo when you put on the aftermarket tires? And why can't you revert back using the same method?
Old Jul 4, 2007 | 10:33 PM
Big Daddy 18C
You went and did it.
I was thinking that, but I assumed he didn't have a stock speedo calibration or the question never would have come up.
Old Jul 4, 2007 | 11:49 PM
jeffisjacked
i had the wheels/tires installed by the dealer when i bought it...they did the calibration on site
Old Jul 5, 2007 | 05:13 AM
puppypower's Avatar
puppypower
Gotcha! Well if that's the case I would just switch to the OEM tires and drive under the speed limit. It's only for a short time and you will be towing. you shouldn't be trying to break and speed records anyway.
Old Jul 5, 2007 | 11:44 AM
jeffisjacked
psh, im driving from kansas city to delaware..there is nothing short about it! lol
Old Jul 6, 2007 | 09:22 PM
echavez1981's Avatar
echavez1981
Why can't u just drive on ur bigger tires, why you have to go back to stock tires?? For towing that is??
Old Jul 6, 2007 | 10:50 PM
bigdavewilson's Avatar
bigdavewilson
The simplest way to calculate your speedo error is with a GPS!
Old Jul 7, 2007 | 08:15 AM
puppypower's Avatar
puppypower
lol, good luck.
Old Jul 8, 2007 | 01:41 AM
Big Daddy 18C
Isn't the GPS error greater than the 5% difference of tire sizes? I have an older Garmin eTrex, but the limitation of the system is the spacecraft. Those things directed bombs randomly all over Afghanistan, so I wouldn't trust them to keep me from getting a speeding ticket.
Then again, the error offset should be a constant, so that a moving average would be fairly accurate. By Dave, I think you've got it!
Old Jul 9, 2007 | 06:21 AM
  #28
bigdavewilson
I think the newer GPS's are pretty accurate. I use mine to troll for lake trout at between 2 and 3 mph and it works great.
Your bomb reference reminds me of a friend who is an armorer in the Canadian Air Force. He always used to kid the pilots that their target was the ground and that they hardly ever missed.
Old Jul 9, 2007 | 10:09 PM
  #29
Firemut30's Avatar
Firemut30
Since we are on the subject, when I change my Edge to my new tire size will it change my speedo, and odometer or do I need to keep my Edge on the speedometer setting to read an accurate speed? Tire Rack also has where you can type in old/new tire sizes to see the speed fluxuations at different speeds.
tjcprop
2004 - 2008 F150
Apr 18, 2014 06:59 AM
Fox_Racing
Jan 15, 2009 09:16 AM
69ford99
2004 - 2008 F150
Mar 12, 2008 09:55 PM
JUMBO_UTE
Oct 31, 2007 02:14 PM
881504x4
Feb 25, 2005 05:25 PM
