Engine Problem
Old Oct 30, 2002 | 11:59 PM
dtech2's Avatar
dtech2
Post Engine Problem
I have a problem with a 302 out of a 1990 F150 4x4 standard.
It has low power as well as missfiring at all speeds under load. Any ideas as to what might be causing this problem Thanx Perry
Old Oct 31, 2002 | 01:27 AM
Pheonix BlackWolf's Avatar
Pheonix BlackWolf
Engine Problem
Have you checked you timing?
I recently had this exact same problem and it turned out I had set my timing to TDC instead of a few degrees before that.
Adjusted my distributor and everything smoothed out nicely.
Old Nov 1, 2002 | 01:20 AM
Franklin2's Avatar
Franklin2
Engine Problem
