guage cluster
Old Jun 30, 2007 | 04:52 PM
Bigblue1977's Avatar
Bigblue1977
Question guage cluster
can you replace the guage cluster from the kind with idiot lights, to the kind with guages. as a plug and play swap or does it require wiring mods
Old Jun 30, 2007 | 05:40 PM
Phinxter's Avatar
Phinxter
as far as i know it would work but you need some sensors to make it work such as a temp sensor, oil sender etc. My truck had the gauge cluster but somebody swapped in an engine from a car and never took the old sensors off to make it work with the new engine. Guy at the parts store owned a truck like mine and he knew just the parts I needed.
Old Jun 30, 2007 | 05:56 PM
plowpusher's Avatar
plowpusher
no the wiring harness is different btwn gauges and lights
Old Jun 30, 2007 | 06:12 PM
Bigblue1977
thanx I thaut so guess I'll jst stick them under the dash
Old Jun 30, 2007 | 06:50 PM
four4x4fords's Avatar
four4x4fords
I tried this conversion many years back and can tell you that plowpusher is correct, the whole harness under the dash needs to be changed to do ithe swap correctly.
Old Jun 30, 2007 | 10:30 PM
Mil1ion's Avatar
Mil1ion
For those that don't know.
The wiring harnesses are different.
The gauges harness is a 18 pin connector
The warning lights cluster is a 14 pin connector.
The Sending units are different.
The HIgh beam light is different
The only good way to is to swap the whole harness over.
Old Jul 1, 2007 | 03:03 PM
Phinxter's Avatar
Phinxter
yeah I think I would just buy some aftermarket gauges.
Old Jul 1, 2007 | 03:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The printed circuits are different too.
