1966 F100 300cid rookie
I am dying to learn about rebuilding or replacing the motor. Nothing fancy, just reliable. Most sites want a vin code, mine starts with F and I dont often see it listed. Another thing, its a 4X4 4spd and it sounds like its at 4000rpm at 60mph. I'm told its the stock tranny as well as motor. Can't help looking for 5th gear. Any ideas would be greatly appreciated!
Post your VIN, and all the rest of the codes from your VIN plate, located on door face near the latch. Everything can be decoded. A 1966 F100 4WD with a 300 I-6 VIN starts off: F11B. F11 = F100 4X4; B = 300 1V.
F11BR762806
color;F
model;F110
body;281
trans;A
axle;C5
color;F
model;F110
body;281
trans;A
axle;C5
B = 300 1V
R = San Jose CA Assembly Plant
762806 = 1966
F = Arcadian Blue
F110 = F100 4X4 / 5600 GVW
2 = Medium Blue Crush Vinyl / Medium Blue Wicker Panel Vinyl
81 = 81A Standard Cab
A = New Process 435 4 Speed
C5 = Dana 60 / 4.10-1 / LIMITED SLIP
It's unusual to see a Dana 60 Limited Slip in an F100 4X4. That may have been special ordered. What is the DSO code?
