Hood lock question
Old Jun 30, 2007 | 01:14 PM
Dads79's Avatar
Dads79
Hood lock question
My truck came with a hood lock from factory. Only thing left under the hood is the cable. I bought another one off ebay to replace it. How does it come apart to run though the firewall ?? Many thanks
Old Jun 30, 2007 | 03:36 PM
X36's Avatar
X36
If you have the complete setup/look where the cable goes into the under hood
latch/theres a cover that goes over the cable where it goes into the latch/unscrew the cover/its held on by 1 sm phillips screw/once you have the cover off/gently pull the plastic dust cap off (if its there)/then peel the looped cable of the round head on the latch(you can make some slack on the cable by pushing on the latches spring)Then after the cables of the hood latch snake it through the fire wall and reattach Good luck
Old Jun 30, 2007 | 07:53 PM
rusty7983's Avatar
rusty7983
if you need parts for it check out stoneys on the industrial hwy in columbia. he has a large inventory of mid to late 70's fords.
Old Jun 30, 2007 | 10:27 PM
Mil1ion's Avatar
Mil1ion
see the routing here.
Old Jul 3, 2007 | 09:05 AM
jeremyd72's Avatar
jeremyd72
I'm putting the latch and cable in my 76. Is there a knock out on the firewall for the cable to go through or do I just put it anywhere?
Old Jul 3, 2007 | 07:23 PM
Mil1ion's Avatar
Mil1ion
There is a dimple to drill a 1" hole thru.
Old Jul 3, 2007 | 09:54 PM
jeremyd72's Avatar
jeremyd72
Thanks Dennis, you're always a big help. I'll check it out in the AM.
Jeremy
