Tranny swap??
Tranny swap??
I have a 1994 F150 4x4 5.0 Automatic and 1994 Full Size Bronco 5.0 Automatic 4x4 129,000 miles that I may be parting out.. the truck has 218,000 miles... an the tranny and motor are getting weak and I was woundering if the tranny out of the Bronco will fit the truck (I know the motor will).... They look the same all but the transfer case. What do you guys thank... Thanks for your help.
The difference would be the transfer case which is basically the same except that the bronco has a shorter out put shaft for the rear end. The bronco also has a fixed flange output where as the truck has a slip yoke in it. Other than the small differences in the transfer case everything should be a bolt in.
