1990 7.3 rough idle and missing
Old Jun 30, 2007 | 08:32 AM
muzzleduster's Avatar
muzzleduster
Hello everyone!
I really enjoy this FTE forum. You folks have been VERY helpful.
My new problem is rough idle and missing throughout rpm range. This cropped up all of a sudden. I thought I needed a new FF so I replaced it. Truck ran great for approx. 1 minute then back to original problem.
I have been reading that you folks plug "the line from #1 injector." Would you please explain that procedure? Any help would be greatly appreciated to get ol' Bessie running smooth again.
In April I replaced the return system rings etc. because of leakage.
1990 F-250HD 4x4 (bought her new 17yrs ago)
277,400 miles
This is my first diesel; I won't buy another because I already have one.
Thanks, Guys
MUZZLEDUSTER
Old Jun 30, 2007 | 05:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
muzzleduster,
Welcome to FTE and the IDI forum.
The return line from the filter to near the #1 injector has a check valve that is supposed to keep the fuel from draining out of the filter and filling with air.
Some people cut the line and stick a long bolt in both ends and then put a hose clamp on both ends to seal it.
Others have removed the fitting in the return header and installed a pipe plug there and used the bolt/clamp in the end of the return line.
Old Jul 1, 2007 | 08:09 PM
muzzleduster
Smile Muzzleduster
THANKS, DAVE!
Did what you said. I really appreciate your help. I found another little air/fuel prob and now ol' Bessie is well on her way to 278K!
1990 F250HD 7.3 4X4
MUZZLEDUSTER
Mike450
19
Jan 21, 2013 02:35 PM
Klindsey1990
3.0L V6
Jan 16, 2013 06:08 PM
bcorg
Aug 27, 2011 07:35 AM
catman900
Apr 20, 2010 04:39 PM
geodiggr
17
Aug 24, 2009 09:24 PM
