C6 Questions
Old Jun 29, 2007 | 10:03 PM
Voh's Avatar
Voh
C6 Questions
I have a '73 C6 that is mated to a 460 i just swapped into a '64. 1-is there a vacuum line (steel) thats required to run between the manifold and module on the back/bottom of the tranny? Does that tell it when to shift? If i bend a new one, what size steel line should i use? Last, is it possible to run the tranny without a cooler?
Old Jun 29, 2007 | 10:18 PM
BigOle'Ford's Avatar
BigOle'Ford
The only vacuum line I can think of than runs to the back would be Modulator. They'll look something like this.
http://www.bulkpart.com/Merchant2/me...e=C-6modulator
I had a friend at NAPA hook me up with one but there fairly inexspensive.
As far as running without an innercooler, I dont think it would work, but I havent really looked for any other types of cooling systems.
Nick
Old Jun 29, 2007 | 10:57 PM
Voh's Avatar
Voh
that modulator is on the tranny, guess that i need to get a line run to it.
Old Jun 29, 2007 | 11:12 PM
dmanlyr's Avatar
dmanlyr
You need to hook up the modulator so the trans will shift properly.
You also need some sort of cooler, if not the factory OEM style in the radiator, then a aftemarket add on cooler. Without one you will overheat the trans fluid in short order.
David
Old Jun 29, 2007 | 11:18 PM
Voh's Avatar
Voh
thank you. Any idea what size steel line i should get to connect it?
Old Jun 29, 2007 | 11:50 PM
dmanlyr's Avatar
dmanlyr
The Factory used about 1/8" to 3/16" or so. Not to critical, it is more that the trans can sense where the vaccume is, that is one of the ways it has of telling where the throttle position is - this is important to help the trans determine what gear to be in / when to shift.
Later trans used a cable to tell the trans the position of the throttle and the computer controlled trans use the TPS to tell it where the throttle position is.
You could of course use a rubber hose in place of the metal tubing, the reason the factory uses metal is that it is more durable when exposed to the exhaust heat. I would recommend metal for this reason.
David
Old Jun 30, 2007 | 12:41 AM
BigOle'Ford
Ive got the rubber hosing, I believe the last person to do a motor swap in my truck just went cheap. Just make sure that if you use metal line you dont create any friction areas. Those lines even though they are metal arent as durable as you think. give them there room.
Good for you its something this simple, I love when I get problems and theyre easy fixes like this! lol Its a hell of alot better than some of the other things that could go wrong
Nick
Old Jun 30, 2007 | 01:17 AM
dmanlyr's Avatar
dmanlyr
Nick
You hit the nail on the head, these are minor issues. I has a buddy about 20 years ago that didn't understand to index the Torque Converter into the flex plate, by the time he called me he had installed and tightened down the upper two transmission mounting bolts to "draw" the tranny in - didn't work so well for him - both mounting ears for those bolts broke off the tranny. opps, time for a new trans case!
It was a expensive lesson to learn. David
Old Jun 30, 2007 | 09:40 PM
stuart1's Avatar
stuart1
Nick
You must use the correct hose for cooler lines.
Air hose will not work.
I use 5/16" steel brake lines.
Get the kind with a steel coil on the outside.
It can be bent witjout kinkind and the coil keeps it from rubbing and creating a hole.
1/8" steel vacuum lines is good. Again, brake line.
