Sponsored by: Real Truck
Weak batteries & cam sensor
Old Jun 29, 2007 | 08:55 AM
Gangster's Avatar
Gangster
Fellow Ford Owners,
My 2002 F-250, 7.3 would not start the other day so I jumped it with one of those expensive aux. starting units. When I turned the key on, ALL the guages pinned to the max. (even the speedo) then they returned to normal positions. After an unusual cranking time, it started up. No problems, all the guages looked normal. I parked it for the week, knowing I would purchase two new batteries this week. The old batteries are Motorcraft, perhaps original, I'm the second owner of the truck (115K miles). It has a new starter, no electronic problems indicated.
I attempted to start the truck this AM; same sequence of gauges pegging and it rolled over not quit at full strength I thought. Nothing, not even an attempt at firing! Is it possible I have killed the cam sensor? I carry a spare in the glove box (NAPA brand). I'm thinking of replacing the old one anyway because of the miliage. Is it possible the engine was not turning fast enough to catch? My experience with older machinery is that if it'll roll over at half-speed it'll catch.
What do you think? Thanks, Hank
Old Jun 29, 2007 | 09:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
I say replace the cam sensor, charge the batteries and try again.
Old Jun 29, 2007 | 10:48 AM
vettdvr's Avatar
vettdvr
I suspect you have a internal short on one of the batteries taking all the power out of your external jumper battery. I would just put in new batteries and try it,, then if it did not start consider the cps. Just my $.02 worth.
Old Jun 29, 2007 | 11:18 AM
Gangster's Avatar
Gangster
Re: Weak batteries & cam sensor.
I took the batteries to PASCO and had them tested; one tested "replace" (also it had a bulge in the end) and I figured the other couldn't be too far behind. I purchase two new ones; increased the CCA from 750 to 850, same physical deminsions. I will install them tonight and see what that does. I'm still thinking about replacing the cam sensor just because of the miles. Thank you for responding, Hank
Old Jun 29, 2007 | 12:05 PM
vettdvr's Avatar
vettdvr
This is a good indicator of internal damage. I am glad you didn't do too much cranking, I have had one with internal damage explode and damage the car,, but not hurt anyone.
Old Jun 29, 2007 | 12:08 PM
redford's Avatar
redford
Been there, done that....also didn't hurt anyone, but an exploding battery will scare the #$%&%$ out of you!
