Sponsored by: Real Truck
ZF 6 Speed ATF Change
Old Jun 29, 2007 | 12:00 AM
duffman77's Avatar
duffman77
Well I just changed the ATF in ZF 6 Speed (2007 F350). What a mess. I must of lost over 1 qt on the floor trying to get it into the fill hole. 2 funnels later I used a plunger type pump to suck it out of the bottle and push it into the hole.
<O</O
There has to be a better way! What are others doing? I do realize having the truck raised would have helped (I have a 2WD).<O</O
Also since I lost so much on the floor I know I didn’t put 5.8 qts back. It ran out of the hole but when I put my finger in to check the level it seemed about 1 cm down from the plug. For others that have done this more successfully, where should it sit after adding the correct amount?
Old Jun 29, 2007 | 05:55 AM
FortyFords's Avatar
FortyFords
Get your self a 5gal bucket (clean) then go to (Harbor freight or Northern tool ).
Get a hand pump with the lid that fits the 5 gal bucket.
Works great no mess!
Rich
Old Jun 29, 2007 | 10:28 PM
duffman77's Avatar
duffman77
24 hours later I notice a little bit of seepage. Anybody have the torque spec for the drain plugs?
Also thx for the response Rich
