Need a part #
Old Jun 28, 2007 | 06:51 PM
reamer's Avatar
reamer
Need a part #
Hi All
I'm looking for the part # for a 1986 F-150 rear SLIDING window rubber seal, but it must have * Factory sliding window AND * groove for chrome.
Most have a gasket for slider without chrome, or Fixed glass with chrome.
I need Slider AND groove for chrome.
Any takers??
LMC has only chrome groove for Fixed, or No groove for slider
D-C has neither.
A factory Ford number is my last hope.
NumberDummy do you surf this '80's site?
Thanks
Reamer
Old Jun 28, 2007 | 08:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by reamer
Hi All
Any takers??
D-C has neither.
Thanks
Reamer
Sure, otherwise I wooda missed this post...
E7TZ-1542084-A .. Weatherstrip-Rear Window with Sliding Glass.
Old Jun 28, 2007 | 10:30 PM
Mil1ion's Avatar
Mil1ion
FTE's sponsor BOTP (Blue Oval Truck Parts) should have it.
The rear window takes the same rubber gasket right up until 1996.
http://blueovaltruckparts.com/catalo...ducts_id=12808
Old Jun 29, 2007 | 12:32 AM
NumberDummy
All very well, Dennis, thank you.
But it now seems (through several p/m's--that's how this all started, as I didn't see this thread originally, I was busy with the CA black plate questions) the OP has a gypo kit, and wants to install the rubber and the chrome frame from the factory kit using the rest of the gypo parts. That will not work. I sent him the p/n for the entire Ford kit = E9TZ-15420A98-A, and a source that has it (they also have the Ford w/strip). The source is also an FTE sponsor.
I should go over to BOTP, and take a look-see. They are only 15 minutes SE of here as the crow flies. With traffic, that's about 45 minutes driving time = Welcome to California!
Old Jun 29, 2007 | 03:23 AM
srercrcr's Avatar
srercrcr
My 83 slider came from the factory with the chrome strip. Mine started rusting after a few years, which made a nice looking truck look nasty. If you're the type to care for it (hand wash/wax) it probably would last. Anyway, the metal was thin too. If it was aluminum like most of the other trim on the truck that would have been good.
I visited an auto glass shop, they installed a black metal strip that hasn't deteriorated in 20 years.
