Aftermarket IN TANK fuel pumps for 92 F150
I am looking for a fuel pump that will give me more volume to the fuel rail to allow for more horsepower gains. I noticed that you can buy them to go in the tanks of the mustangs, but their doesnt seem to be anything for the dual tank F150's that use one pump in each tank. I was planning on redoing all of the fuel lines in the truck anyways because I have already had some trouble with the lines from the back tank leaking, and I also cant seem to keep the back tank from eating up fuel pumps. I would like some opinions, or of some knowledge on where to find a fuel pump that puts out more volume than stock and will go into this set up without to much dickin around. The truck is a 92 F150 with dual tanks. The rest of the mods are in the signature.
Received 1,032 Likes
on
Originally Posted by Conanski
There is a Carter 155lph pump that is very close to the stock pump dimensions that will fit with minor modifications, but most of the mustang pumps are physically too big to fit inside the resovoir that contains the pump and check valves on these trucks. For the record the Carter I had didn't last more than a couple years. That said, the stock pump wil support 300hp give or take, and your 5.0 is mainly stock so you don't really need a pump unless you have heads, a cam and bigger injectors on the shelf waiting to be installed.
on
Thanks very much for the input. Just out of curiousity, what are you running now for horsepower and torque numbers out of your 351?
And would I need to install a couple of check valves for the return lines and a switching valve of somekind to switch between each tank with the carter pumps? I am trying to get all, well most, of my ducks in a row for my 408 stroker motor.
78 Ford F150 460
17
06-24-2012 11:31 PM
predaina
29
03-29-2011 07:07 PM
bdinger
16
02-05-2006 05:27 PM
