Sponsored by: Real Truck
f250 stalling
Old Jun 28, 2007 | 01:09 PM
31fountain's Avatar
31fountain
f250 stalling
has anyone been having problem with 5.4 stalling while on idle.I've taken my ,'99 f250 to my mechanic but he can't seem to find the problem,I don't trust the Ford dealers down here in Miami
Old Jun 28, 2007 | 01:47 PM
sowder's Avatar
sowder
might try cleaning your IAC idle air control valve, or replace it, its easy, sometimes cleaning works for awhile, sometimes it don`t, its worth a try.
Old Jun 28, 2007 | 01:59 PM
msgtg's Avatar
msgtg
Hey 31, welcome to the site. Just hang on....one of the pros will chime in here shortly!
Joe
Old Jun 28, 2007 | 05:59 PM
FortyFords's Avatar
FortyFords
Change the IAC. (Idle air control valve)
The #1 cause of idle problems on our trucks.
If you goto the top of this forum (tech folder )there is a picture and procedure .
Its the silver canister thing on the back of the throttle body.2 screws to change.
rich
Old Jun 29, 2007 | 09:01 AM
31fountain's Avatar
31fountain
thanks to all,i'll give that(IAC) a try.someone also mention the cps crankshaft position sensor,but this seems to be a bigger job
Old Jun 29, 2007 | 09:05 AM
redford's Avatar
redford
FTE Leadership Emeritus
CPS is usually an issue on the 7.3L PSD engine.
Old Jun 29, 2007 | 09:09 AM
JeremyJudd's Avatar
JeremyJudd
A quick test for the IAC is just to unplug it. If the truck dies, or almost dies, it's working. So said my Haynes manual anywho... having a similiar problem with my Ford Ranger. Heard that a TPS can cause similiar problems with idle when it starts to go bad. I'll test mine and if that ends up being the problem, I'll let you know.
