cleaning grounds
Old Jun 27, 2007 | 10:33 PM
atillett's Avatar
atillett
cleaning grounds
hello, my fuel gauge does not work and i have searched the forums and i think that i have a bad gound some where. the truck is a 1988 f-250 hd 351. my question is where are all the grounds supposed to be so i can check and see if they are hooked up and clean them up. thank you. allen t
Old Jun 28, 2007 | 07:19 AM
subford's Avatar
subford
The fuel tank ground (G801) is located on the left-hand (driver side) inner fender behind Headlamp.
The fuel pumps also use this same ground point.
Old Jun 28, 2007 | 11:10 PM
atillett's Avatar
atillett
thank you, well if the fuel pump is on the same ground then i guess i still have a problem. search forum here i come.
Old Jun 29, 2007 | 07:13 AM
subford's Avatar
subford
Fuel system wiring, just click on the link below.
If you have two tanks
If you have one tank
Cluster gauge
By the way here are links to all of the ground locations on the 88 F-series:
Diagram of locations
Ground Locations
Bottom right on this one
Page two of grounds
Old Jun 29, 2007 | 08:40 PM
str8racing's Avatar
str8racing
Can i get these for a 90 f350 with a 460?
Old Jun 30, 2007 | 08:36 PM
atillett's Avatar
atillett
i was just wondering if the switch could be bad and still be getting power to the pump.
Old Jun 30, 2007 | 08:41 PM
subford's Avatar
subford
Yes that is possible.
Old Jun 30, 2007 | 08:42 PM
atillett's Avatar
atillett
i am running the back tank and seems to run fine gauge just does not work, i have already run out of gas twice, i think my truck uses more gas when the guage does not work (lol). thank you
Old Jun 30, 2007 | 08:46 PM
atillett's Avatar
atillett
i will buy a switch next week. and post it, to see if it works, it seems that may be it since the front gauge works, thank you very much for your info.
Old Jun 30, 2007 | 08:54 PM
subford's Avatar
subford
I have no information on 1990 or 1991 F-series Trucks other then these links.
Engine wiring-1990 F series 7.5L vin "G"
Chassis wiring 1987-91 F series
Chassis wiring 1990-1991 F series
Fuel-selector 1990 F150
1990-1996 F series Fuel system
