Quick injector Question
Old Jun 27, 2007 | 10:02 PM
grinekb's Avatar
grinekb
Question Quick injector Question
I took my truck in and paid the dealer to look at it today. Well 85$ later and i think they are wrong. They want 500$ to change out the #5 injector. So I went out in the parking lot and cranked the truck up. I popped the hood and unplugged the #5 injetor and it started running really rough. So in my small knowledge of desiel engines, i think that the truck shouldn't run any different if that injector is bad. The mechanic was standing there and told me that I was wrong. Now i know he is probably right. But can someone give me an explanation without having a stick up there you know what?
Old Jun 27, 2007 | 11:15 PM
BC Powerstroke's Avatar
BC Powerstroke
I assume you are out of warranty as ford wants to charge you.
I am not as famliar with injectors but from my understanding is that as a last resort before considering changing the injector(s) some are experiencing good results with hotshot addictives to help improve/prolong injectors.
See this link
https://www.ford-trucks.com/forums/6...-additive.html
However the forum guru's should tune in to help you but they will need more information from you like your kms and more details of your symptons and when does it occur, etc.
For example injectors normally last approx. 250,000km. However some do fail prematurely like my company truck #5 injector at approx. 35,000km which warranty replaced.
My $0.02, Ford could fix what they need to fix when covered under warranty at their cost but when the bill is mine (out of warranty) I will contact or travel halfway accross the continent if I have to to get service from repurtable company's such as LIPD, Innovative, Elite or VJ's.
Good luck
Old Jun 28, 2007 | 07:05 AM
BowTieHatr's Avatar
BowTieHatr
if it is bad, then the truck should be running bad at some point, whether its cold or hot.
Old Jun 28, 2007 | 10:09 AM
grinekb's Avatar
grinekb
can an injector be partially bad?
Old Jun 28, 2007 | 10:16 AM
Deluxe05's Avatar
Deluxe05
Given the very tight tolerances within various pieces of an injector, I would say it is possible for an injector to be partially bad. I would like to think that it would operate slightly different between hot and cold or partial load vs. full load. But, that would just be speculation on my part.
Old Jun 28, 2007 | 12:57 PM
blackhat620's Avatar
blackhat620
If you are asking can an injector be performing at less than 100% and the answer is yes. Generally injectors as with most parts do not fail all at once, it is a gradual process of declining performance. Hence the reason the diesel tech performed a contribution test to determine the performance level of each injector. The engine and PCM compensate for the weak injector(s) until they can no longer compensate and then a major problem experienced by the vehicle user.
Old Jun 28, 2007 | 08:22 PM
grinekb's Avatar
grinekb
the paper work i did not show a contribution test. All it showed as the code he pulled off the truck that i had already done myself. And that cost me 85$
Old Jun 28, 2007 | 08:26 PM
blackhat620
You are going to pay the dealer a minimum shop charge, if it takes 5 minutes or and hour. As for unplugging the injector connector in the parking lot that is not going to tell you if the #5 injector is starting to fail. The PCM is much more sensitive in injector imbalance than totally eliminating the injector from the circuit.
MauleOne
Sep 13, 2014 12:03 PM
19tanker
26
Sep 8, 2014 03:10 AM
ol-blu
Mar 3, 2013 07:06 PM
milman
Dec 3, 2012 08:26 AM
1978fordf250
Jun 24, 2006 11:32 AM
