Sponsored by: Real Truck
Front Hub Replacement Help!
Old Jun 27, 2007 | 09:40 PM
Kevdadi's Avatar
Kevdadi
Exclamation Front Hub Replacement Help!
My buddy's 1999 f-250 superduty 4x4 model is in need of a new front axle bearing hub. Can any of you gentlemen help with the correct part number, and the most likely place not to get ripped off (i.e. Ford Dealership)?
Your help is greatly appreciated!
Old Jun 27, 2007 | 09:42 PM
yamaguy's Avatar
yamaguy
check out this fellow FTEers site for a good how to http://guzzle.rbmicro.com/nblube.html In my area it seems to run about mid $300 or so.
Old Jun 28, 2007 | 10:37 AM
harald's Avatar
harald
I don't have the part numbers handy, but powerstrokeshop.com has part numbers listed in their kits. I recently bought their front ball joint kit for my 2000 and they had the best prices for all the parts. They also have front bearing kits with all seals/etc. rockauto.com also has great prices on factory parts.
Old Jun 28, 2007 | 10:42 AM
DetailerDave's Avatar
DetailerDave
You need to know if it is early or late model 99. Hubs are different. Early are more $$ than later ones. Non-ABS is also more $$ than ABS. Different brand parts have different part numbers as well. If you want parts locally vs mail order, a location would help, too. Local for me was $217 for late ABS hubs, over the counter.
Old Jun 28, 2007 | 01:14 PM
Racerguy's Avatar
Racerguy
Make sure you check prices at your dealer compared to other parts stores too. They aren't always more.
