Psd Excursion fuel problems
Old Jun 27, 2007 | 09:39 PM
dino12gauge's Avatar
dino12gauge
I have a psd Excursion and the other day we were going swimmimming and after pulling a large hill it started running rough. I left the swimming hole and a bout 5 miles later it died. I let the pressure off with the lever on the bowl and it ran fine again. So I thought it must be the filter and went to the parts store to get. After it died and repeating letting off pressure about 5 times to get 8 miles. I came home changed filter and it ran ok for about 15 miles. I read about maybe having a leak in quick connect. Any other ideas?
Old Jun 27, 2007 | 11:38 PM
97REDPSD's Avatar
97REDPSD
I would try cps
Old Jun 28, 2007 | 01:34 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I would recomend his one http://www.puredieselpower.com/catal...?reviews_id=51
Nick
Old Jun 28, 2007 | 10:52 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
What year is your X?
Old Jun 28, 2007 | 01:52 PM
n3qdz's Avatar
n3qdz
I had a somewhat same problem. After replacing the fuel pump problem solved.
Old Jun 28, 2007 | 07:14 PM
dino12gauge
Its a 2000 X.
Old Jun 29, 2007 | 10:08 AM
dino12gauge
Changed cps, still running rough. Took of fuel pump and blew air through it. Is there a filter in the tank or screen that could be clogged?
Old Jun 29, 2007 | 10:36 AM
vettdvr's Avatar
vettdvr
Which fuel pump?
Old Jun 29, 2007 | 12:12 PM
dino12gauge
I blew out the feeder pump. I got a scanner from the shop up the road. I am getting codes P1316, P0478, and P0236. Can anyone narrow down what I need to look at?
Old Jun 29, 2007 | 02:19 PM
dino12gauge
Talk to a friend at ford dealer he said it sounded like harness under valve cover. I pulled the driver side and then noticed the wires on the opposite side of the valve cover were bare. So I tried to seperate them and all the insulation crumbled. Now I have to find a junker to get another plug and splice it in. The guy at Ford did not tell me price for entire harness,but that it was extremely expensive.
Old Jun 29, 2007 | 03:21 PM
Brians97F250Crew's Avatar
Brians97F250Crew
you mean the wires under the valve cover were crumbling or outside it? You might be better off with getting a new one. You might end up with the same problem with a used wire.
Old Jun 29, 2007 | 08:47 PM
n3qdz's Avatar
n3qdz
I would think it would be the one in the tank. I didn't know that it had 2.
Old Jun 29, 2007 | 09:28 PM
dino12gauge
It was the wires that plug into the ones that are in the valve covers. The dealer list is $650. for the harness under the hood. I patched the drivers side and then discovered it was doing the same thing on the pass side. Is this a common problem? I need to find an aftermarket one if there is such a thing. I did find a used one for $150 from junkyard. I really like this X, but I have hadf to do a lot of work on it since I bought in October.
Old Jun 30, 2007 | 12:39 PM
dino12gauge
Well I fixed both sides of wiring harness at valve covers. Still running rough. Is there a chance these wires touching could have damaged injectors or something else? Do you have unhook batteries to reset computer?
