4Brl or TBI?
Old Jun 27, 2007 | 07:02 PM
hogdogs's Avatar
hogdogs
4Brl or TBI?
If money were not an issue... What would render better performance, fuel economy and reliability? Holley four barrel on an offenhauser intake or a 2barrel holley stand alone TBI system on an adapter? The dual plane effect would reduced I guess as the primarys are fed to a different smaller plane and secondaries go to a larger set of runners....
Brent
Old Jun 27, 2007 | 09:13 PM
Conanski's Avatar
Conanski
The stock EFI system beats both your options on all counts, with the right combination of parts.
Old Jun 27, 2007 | 09:31 PM
hogdogs's Avatar
hogdogs
Stock is out as I have none of the parts, 'puter, wiring harness is no longer fully stock with connectorsfor efi... etc...
I have a one brel. GAS HOG of a carb...
I intend to put in an R/V cam, headers intake and either the 4brl or tbi...
Brent
Old Jun 28, 2007 | 07:32 AM
lostin90s's Avatar
lostin90s
Well then money is issue I can get all parts for used EFI (all harnesses also)for less then you will pay for the intake . And it will almost run upside down if needed.
But on my plow Truck a well set up 4 barrel will Preform just as well as a 2BL just keep foot out till needed.
Old Jun 28, 2007 | 08:30 AM
hogdogs's Avatar
hogdogs
I will not be going back to the factory computer... I am likely going to pot that offy intake tiny holley 4brl they suggest and headers... Cam can wait...
That little one brl really sux alot more gas than I thought it could but am told that I will need much less throttle with the 4 and better intake thus actually see some improvement. Hopefully be able to finer tune the truck too...
Brent
