Fuel injector difference?
Old Jun 27, 2007 | 06:36 PM
scottek's Avatar
scottek
Does anyone know what is different between the F1ZZ-9F593-C and the F0TZ-9F593B fuel injectors? The vehicle in question is a 96 F250 with a 5.8 L.
Thanks,
Old Jun 27, 2007 | 07:44 PM
EPNCSU2006's Avatar
EPNCSU2006
There was a design change with the Bosch injectors, but I'm not sure what time. Are both of those numbers the same flow rating?
Old Jun 29, 2007 | 10:23 AM
scottek's Avatar
scottek
I think so? They are OEM numbers for the 5.8L. P/N search shows either P/N for my '91, but only shows the F0TZ-9F593B for my '96. I was curious if I would encounter problems using the F1ZZ-9F593-C with my '96 wire harness and computer.
Old Jun 29, 2007 | 11:54 AM
EPNCSU2006's Avatar
EPNCSU2006
I'm not really sure what the difference would be. I'd almost think that the newer part might have a little better spray pattern, but it probably doesn't make much difference which one you go with, so long as the flow rate is the same.
