Hi everyone! I am ordering a 4" mbrp turbo back exhaust system for my '04 f-250 psd. I want to run cat and muffler delete pipes also but the D'fuser site I am ordering from says the muffler delete pipe only fits stock and the cat pipe didnt specify. Do they make these delete pipes to fit a bigger exhaust?
HeavyAssault is right - we do build our muffler and cat deletes to fit our systems. The cat delete pipe won't fit to a stock downpipe on the Ford but you have a turbo back kit so this won't be an issue. Any of this sites supporting vendors should be able to hook you up.
Been doing some research myself. They make the cat and muff delete, go to there website to get the part #. These prices are for 4" 6.0 04 SC, SB, but I think it fits all but reg cab for the 304, cheaper for the 409
Part numbers for '04 F250 6.0L T/B single 4" system in 409SS is S6206409 - cat delete to fit is FS9414 - muffler delete is MDS930. This gives you the option to remove and replace the cat as you need to. This system also comes as an Off Road system that removes the cat with no option to replace. (S6212409) Any of this sites supporting vendors should be able to access these parts for you - we're always here to help answer questions.... good luck!
