General Automotive Discussion
Engine guru's please
Old Jun 27, 2007 | 01:25 PM
385seriesHemi's Avatar
385seriesHemi
Question Engine guru's please
Ok so im timing the race car, its a 305 chevy with vaccum advanced. When i time it into the specification it runs terrible, but when I adjust the distributor so it actually runs good its not even on any timing mark on the timing cover tab.
Could this be a stretched out timing chain? Its got some power...... for a 305 anyways.
Could the timing gear be off 1 tooth also or no?
Thanks for any input, its very appreciated and is benefiting me also.
Old Jun 27, 2007 | 04:59 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Chevy harmonic balancers are two pieces, they have a rubber isolator between the inner hub and outer ring, they can rotate on it.
Especially if it is a 377/392 stroker…..
Old Jun 28, 2007 | 12:05 AM
385seriesHemi
Ok, well thats another thing I had not known. Thanks. Are there any things about Ford harmonic balancers I should know if I were to run into in the future?
Old Jun 28, 2007 | 12:52 AM
kermmydog's Avatar
kermmydog
My 460 balancer had to be replaced for that reason also. rubber rots out and the outer ring turns. I guess if you ran one long enough in time it would come flying off destroying things.
Old Jun 28, 2007 | 05:45 AM
IB Tim's Avatar
IB Tim
After finding TDC, using the positive stop method, & degree wheel, once cam is degreed go back to TDC, disassemble all paraphernalia for degreeing and place HB on it…..scribe a line with a straight edge, on the face of the HB from pointer down through the Key "WAY" slot...that way at any point in time you can use a flashlight and check to see (if you think it has slipped). If the two rings move at all ….you will see the scribed line...not lining up...easy check.
This works for Ford Chevy.... any HB that is two piece.
Or you can pin the ring in three equal places, with roll pins, install the roll pins and spot weld all three holes on the outer ring, just so you won’t shoot the pins out when it is turning.
Old Jun 28, 2007 | 11:11 AM
385seriesHemi
Sweet, I still need to buy one of those degree wheels also. Thanks a lot Admin
Old Jun 28, 2007 | 12:41 PM
Racerguy's Avatar
Racerguy
Check to make sure there aren't 2 timing pointers. Some small block Chevs had the pointer at the side and others had it behind the water pump. You aim the timing light behind the water pump, from above.
Safe to assume you have the timing light pickup lead on #1 cylinder? That's the front one on the driver's side, not like a Ford where it's on the passenger's side.
Old Jun 28, 2007 | 01:51 PM
385seriesHemi
Yeah, theres only 1 timing tab behind the water pump. I never knew some chevys had 2 timing tabs.... maybe because thats a Chevy thing. Yeah I knew the #1 cylinder was on the drivers side like Chrysler & the other GMs prior to this thread, thanks though Raceguy. Anything else I should know?????
Old Jun 28, 2007 | 02:24 PM
Racerguy's Avatar
Racerguy
How old is the timing chain? Was it installed correctly if it's fairly new? On a Chev the marks on the timing gears aren't the same as on most other engines. The mark on the crank gear isn't straight in line with the keyway and that fools some people.
Otherwise I'd check what Admin said.
Old Jun 28, 2007 | 08:22 PM
385seriesHemi
I have no clue if its new because we bought the car with the engine already in it.
Old Jul 2, 2007 | 10:18 PM
warthog5's Avatar
warthog5
HeHe This must be a circle track Bomber class car? or a Enduro car?
Old Jul 2, 2007 | 10:26 PM
385seriesHemi
Yeah its a bomber
Old Jul 3, 2007 | 09:52 AM
5_labsownus's Avatar
5_labsownus
It sounds like the Dizzy has been removed and is at least 1 tooth out or more!
Old Jul 3, 2007 | 11:30 AM
DOHCmarauder's Avatar
DOHCmarauder
(Why you screwing with the guy??)
Old Jul 4, 2007 | 11:55 PM
jimdandy's Avatar
jimdandy
Initial advance is set with the vacuum disconnected, usually about 8* on a chevy.
Using a timing light, set the initial advance, watch the timing light and speed up the engine. This is without connecting the vacuum line. The timing should advance due to the mechanical advance inside the distributor. You should get a good 12 plus degrees advance.
If it does not advance, the mechanical advance is stuck/not working.
If the mechanical advance is working, connect the vacuum line and repeat the process. The timing should advance to around 34/36* total. If it doesn't advance, the diaphragm in the pot is probably broken and the pot needs to be replaced. jd
