F250SD VSS Wire
Old Jun 27, 2007 | 09:50 AM
knecoli22's Avatar
knecoli22
F250SD VSS Wire
First time to post, sorry if I leave out any needed info.
Looking for help locating the VSS wire for installing a Pioneer AVIC-D2. I have an '03 F250 SD Crew Cab 2X4 7.3L. I have done some research and believe I can tap into the wire in the passenger kick panel. It appears that the wire is gray/black?
If this is the correct wire what is the best method to tap into it? Will a T-tap work?
Can anyone confirm or deny?
Thanks in advance!
Old Jun 27, 2007 | 10:26 AM
glruff's Avatar
glruff
FTE Leadership Emeritus
That is the same color wire, same location I used to install my Eclipse AVN-7000. Yes a T-tap will work, tape it good.
