truck won't start
Old Jun 26, 2007 | 07:56 PM
mcguffee's Avatar
mcguffee
truck won't start
hi! I have a 95 ford f250 powerstroke that get used one or two times a week. last week it would take a couple of times to get it started , I found the eng harness melted at on one plug , but my wife had to use it . it started ok and she drove 2 miles to gas station and turned it off. it has not run since. this motor has 2000 miles on rebuilt injectors,less than 500 on new oil, 2nd change since injector change. just replaced pass side valve cover gasket,engine harness,cam position sensor,ipr o-rings, filled oil res after doing o-rings. I put pressure guage on hpop to check pressure, no reading, took line and put in clear pint bottle, took 10 seconds to half fill. do you think I should replace ipr first ? also only code is p0476, I erase code and after cranking it comes back. pleeese help !!
Old Jun 26, 2007 | 09:01 PM
Fomoko1's Avatar
Fomoko1
Welcome MC, great to have you on board.
By searching the forums as you are now doing you`ll find which forums to post in for help.
FTE is the best Ford truck site and there is plenty of good help here.
Be sure to visit your local Georgia Chapter https://www.ford-trucks.com/forums/forum82/
Old Jun 26, 2007 | 09:29 PM
mcguffee's Avatar
mcguffee
thanks, so far I have read some interesting post.
Banditmc
New Member Introductions
Nov 6, 2018 01:07 PM
really ole man
Nov 14, 2017 08:11 PM
Harwell
Sep 25, 2017 08:30 PM
Sdalerio
Apr 17, 2013 08:02 PM
jimmy7339
Aug 17, 2008 07:47 PM
