The past couple of days, when I start it the first time in the morning, it goes romp-romp-romp..... I don't know how long it would do that for 'cause I give it bit a of pedal and it goes away. There might be some contributing factors to this condition, and they are
1- running B100
2- my hp xover line has a very small leak at the o-ring
3- I gotta swap out the leaky o-rings on my filter bowl drain
My early 99 DRW has done the romp thing since new.. Two years ago i switch from Delo 400 to Shell Rottela Synthetic 5w-40 and the engine has not romp once since.. Your oil is not supplying your injectors properly.. I use synthetic year round.. Yes, it more money but is better for your engine and especially your turbo.. I will never go back to dino..
in-tank mods and changing to synthetic oil were the two most dramatic differences in my trucks smooth start-up and purring idle, even in winter. Definitely get that cross-over leak fixed.
I've been debating over switching to synthetic- a good portion of the posts I've read on dyno vs. syn point to using dyno??? I am almost thinking it's the leaky xover pipe loosing oil after shut down or something which lowers the injector pressure till the rails fill up again- just a guess. What about the "synthetic causes leaks" fear??
I don't think it is the oil...your climate is too warm to give romps running 15-40W dino. If it was the oil, it would have been much worse over the winter (even though you don't really have winter where you are ).
I would not fear the "synthetic causes leaks". I switch to synthetic 5-40W in the fall (because we have real winter here and 5-40 syn stops the romps from lack of cold temperature pour point of 15-40 dino) and back to 15-40 dino in the summer...never a leak (knock on wood).
As far as romping only in cold weather, mine did it after sitting in my heated garage overnite until i switched to Shell synthetic. And as far as additional leaks are concerned, i really have not expenienced any in the last two years.. If you are a guy that does not like to wait for the engine exhaust to cool abit before shutting down, the synthetic route is the one to take.. saves your turbo..
Roger that- I am wondering when I'm gonna have to start changing sensors- I only changed the CPS by mistake (ran out of fuel!!) so I'm guessing that maybe it's time to start collecting various sensors.....
wow, i am confused, the only romping I have is from poor pedal control, sorry, self control..
is this romping almost like a missfire in the winter months?
