Driveshaft Questions
Old Jun 26, 2007 | 08:44 AM
netscaner's Avatar
netscaner
I have read in many posts that it is important to mark your driveshaft before removal to keep everything in it's original alignment. This sounds reasonable for several reasons.
But I remember in one thread someone mentioning they didn't know their original alignment and someone stated that the best course of action was to lay the shafts on a flat floor and make sure that the flats matched, then mark them, and the worst you could be off was 180 degrees, making it a 50/50 chance that it's right, and you could try it both ways to see which was best.
Do they come from the factory with the yokes exactly inline ??
I havn't gotten mine apart at the carrier bearing yet (hang-up getting the cup over the rubber seal off), but can clearly see that the yokes from the front shaft aren't exactly aligned with the yokes from the rear shaft.
Is this alignment that important ??
Old Jun 26, 2007 | 06:09 PM
Dean88's Avatar
Dean88
Huh I didn't know you should mark your driveshaft when you take it out. When i took mine out, I just took it out, put new u-joints in it, then slapped it back in, maybe I was just lucky.
Old Jun 26, 2007 | 08:40 PM
mhg's Avatar
mhg
it all depends on the balance of the individual shafts and
the angles from one to another
the more lift the greater the angle the more important the
alignment
Old Jun 27, 2007 | 07:34 AM
netscaner's Avatar
netscaner
I would think that by design, the best scenerio should be both shafts independently in balance, and the yokes from the two shafts 90 degrees offset from each other.
Old Jun 27, 2007 | 02:38 PM
alxsnmr's Avatar
alxsnmr
I have seen that it is imporant to keep the drive shaft in alignment with the axle yoke and the trasmission output. I think that it is more important though to keep your drive shaft yokes in alingment on slip shafts. Otherwise this could cause added wear to the u-joints.
