welded hitch
Old Jun 26, 2007 | 12:07 AM
DieselRunner's Avatar
DieselRunner
welded hitch
just got a hitch and bolted it up i have a welder that can weld it to the frame is this popular, its probably not nessesary but i figure it would help, any down sides other then removing it?
Old Jun 26, 2007 | 12:30 AM
khadma's Avatar
khadma
Carpenter Local 745
Is the hitch installed according to the instructions of the manufacturer?
Did you use new/correct bolts, nuts and washers?
Is this the correct hitch application- for the truck?
If so, I would leave it at that.
No weld. IMO.
Old Jun 26, 2007 | 01:52 PM
rclarke's Avatar
rclarke
Modern truck frames should never have anything welded to them. If you are completely convinced you need to weld it be sure to disconnect all computers and the batteries from the frame. One hot arc can fry the computers.
Old Jun 26, 2007 | 05:55 PM
firesoutmatt's Avatar
firesoutmatt
I know that when I had my fiver hitch installed they told me it had to be welded to the frame to pass DOT inspection. It passed but don't know if it would not have if it wasn't. This was from a large volume hitch installer and they seem like they know what they are talking about.
Old Jun 26, 2007 | 05:59 PM
DieselRunner
yeah its a brand new hitch with new hardware so ill just leave it alone.
thanks.
Old Jun 28, 2007 | 02:34 PM
5_labsownus's Avatar
5_labsownus
Most vehicle Mfgs state to not weld on a frame because it will weaking the frame unless done correctly. In most states welded on hitches don't pass inspections and are not as strongly secrured as with bolts.
Old Jul 1, 2007 | 05:30 PM
fasthauler's Avatar
fasthauler
Man I have got to admit that I have never heard this. I've been around for a lot of years and never saw a hitch welded. My hitch wasn't welded on my big rig and I went through a lot of DOT inspections in the years of driving.
Old Jul 5, 2007 | 11:07 PM
dnvoss's Avatar
dnvoss
welding to the frame is a bad idea
