2006 Remote Starter
Old Jun 25, 2007 | 11:32 PM
bigdaddy112's Avatar
bigdaddy112
2006 Remote Starter
Bought my 2006 FX4 Level II used with not a lot of info on it. Just discovered it has the Securilok kit with a remote starter. For the life of me I cannot figure out how it works. Any help is greatly appreciated!
Thanks
Old Jul 15, 2007 | 09:20 PM
amish77's Avatar
amish77
Man I've got nothing, but here's the thread bump. My only guess is that there might be a way to re-program the thing. Try disconnecting the battery for five to ten minutes and then re-connecting. This might and I emphasize might reset the system.
Old Jul 15, 2007 | 09:52 PM
Peter94's Avatar
Peter94
Welcome to FTE! I wish i could help you with that. Is the securilok thing an aftermarket ford product or is it another brand?
Old Jul 16, 2007 | 07:05 PM
fflintstone's Avatar
fflintstone
Here's a cut and paste from a deisel forum but it's a Ford and I thought you might give it a try.
And here is the Securilok programming and wiring info that NowYouKnow previously scripted,
"I use the keyless ford piks all the time with no problems. Basically you need to hook the black wire up to your ignition 3 (-) out or whatever wire they have dedicated for the active out etc. Then run the red wire to constant. Tape up or cut off the white wire you won't need it. Make sure you secure the ring around the key cylinder good. Now once you have your remote start ready to go you will NEED 2 keys for the truck and the remote transmitter for the remote start.
Put key 1 in the ignition and turn it up 2 clicks and watch the theft light or LED in the dash. It will stay solid for a couple seconds and then go out. AS SOON as it goes out quickly remove that key and put the second key in and turn on the ignition. Again watch the light and AS SOON as the light goes out remove the key and hit the remote start button on the transmitter. The ignition will fire up and watch the light again. If that light is blinking hit the brake and shut it down because it didn't work right. If the light is solid, you did it right its working. You just have to do that whole process quickly if you don't it won't work. Give that a try and let me know if it works. Good luck"
Here's the link to the thread for more info.
http://www.the12volt.com/installbay/...sel&PN=0&TPN=1
Here's another
http://forums.focaljet.com/5168120-post2.html
Fred
