Sponsored by: Real Truck
weird electrical bug
Old Jun 25, 2007 | 09:51 PM
BobbyDiesel71's Avatar
BobbyDiesel71
My 2002 F-350 today had an issue with the power window switches on driver's side. I could not roll down either window. I had the truck key in ACC and started truck and NO POWER at switch. After a few seconds they worked.
Very weird!
I am going in tomorrow for I think another wheel bearing on my driver's side. This will be the second replacement. UGH!
Old Jul 15, 2007 | 09:07 PM
amish77's Avatar
amish77
That is weird, have you figured it out by now or was it a one time deal?
Old Jul 16, 2007 | 08:20 AM
sofdchief's Avatar
sofdchief
switch
My '02 did about the same thing. One day it would work intermittant, then the next it was gone! Luckily the window was up at the time. I replaced the switch unit in the arm rest, and never had another problem. I don't remember what the cost was....maybe $30 or so. took about 10 minutes to complete the job. You may want to try replacing the switch and see if that works for you.
Old Jul 16, 2007 | 10:11 AM
BobbyDiesel71
I will try that
thanks
