Chips and Manual Transmissions
I have heard alot about performance chips really making the biggest difference in the way an automatic transmission shifts. Does anyone own a truck with a manual transmission and chip installed? What improvements have you noticed i.e faster accelleration, more torque, improved MPG?
I'm a bit late seeing this question but here goes: I had a Superchips chip in my 97 4x4 SC 5speed V8. I also added a Flowmaster cat-back and a K&N air filter all before adding the chip. No improvement with K&N, a little improvement w/muffler and HUGE improvement with the chip. Really woke up that little V8. Better mpg, better take-offs, shifting points changed but once I got used to them, it was no problem. The truck would get up and get moving faster than before. Well before chip it drove like a slow moving turtle. After chip, the truck was a real pleasure to drive. Down side to chip: must use premium gas but I figured it was worth all that extra performance I was getting. And the worst problem it caused for me was this extreamly bad case of lead-footitist!! I've now got a different truck, a 6 speed manual Diesel. After about 500miles, I added the standard Superchips chip to it. This gives 50hp/100torque. I could tell the truck had a little more get-up to it but the main thing this chip does is improve fuel milage when towing. Superchips also has more impressive chips for the diesel but I figured the standard would do just fine for my needs. The superchip also removes your speed limiter and ups your rev limiter. Hope that helps some.
640 CI Aluminum FORD
Computer Chips & Tuners
Apr 23, 2011 04:55 AM
nocluehere
Mar 7, 2003 05:17 PM
mickey mouse
All Things Towing
Apr 16, 2002 07:40 AM
1999, 2000, chip, chips, diesel, f250, ford, manual, performance, power, superchips, trans, transmissioms, transmission, transmissions, truck, tuner, work
