Lowered 76
Old Jun 25, 2007 | 08:27 PM
hp246's Avatar
hp246
Lowered 76
New to this forum. Hope someone here can help me out. My project is a lightened and lowered 76 F-100 shortbox. I've lowered the truck 3 " with a DJM suspension kit. The doors, and front and rear fenders are fiberglass. Here are my questions:
1. I want to use polycarbonate instead of glass in the side and back windows. This would eliminate the vent windows. Anyone know if there is a stock year window gasket/anti-rattle set that would work from a latter year truck?
2. Anyone with have an idea for fabricating/installing a lightweight window mechanism.
3. Does anyone make fiberglass bumpers for this truck?
Thanks
Mike
Old Jun 26, 2007 | 01:13 PM
trinogt's Avatar
trinogt
Sounds like a cool project... I am guessing it is a flareside?
You could check here for power window kit, near the bottom of the page:
http://www.watsons-streetworks.com/power_stuff.html
Or look here: http://www.yearwood.com/store/produc...s=&id=ROCPKW01
I have no experience with these, so you might have to do your homework on them. Better yet, contact the suppliers directly to ask your specific questions.
As for felts/weatherstrip, I think it is best to stick with the year you need, meaning '73-'79 truck kits. You can get the repros through the FTE sponsor.
Got any pictures so far of your progress?
I LOVE the 2WD Fords!
Old Jun 26, 2007 | 02:05 PM
hp246's Avatar
hp246
Thanks for the response trinogt.
It is a step side. I know that I can install power windows set for flat glass. I was thinking something more along the line of the manual systems that they put in the factory drag cars. Really a strap mechanism to save weight.
The fiberglass doors don't have vent windows. I would like to elimante them, rather than retrofit the doors. Besides, part of this exercise for me is to try to see how light I can make this thing. I am planning on fabricating the rear bumber out of 5" aluminum U channel. It matches the stock rear bumper pretty closely.
Also am retrofitting a 460/C6 combo if anyone has exerience with this swap or header setup, please let me know.
Old Jun 26, 2007 | 02:32 PM
psquare7575's Avatar
psquare7575
I converted my 79 F100 2wd from a 302 to a 460/c6
I used the OEM style towers and mounts, I got them on ebay. For the tranny I had to get creative: I used a lincoln C6, which is longer and uses two small 'square' rubber pieces for a rear mount.. I drilled two holes and bolted the tranny to the xmember.
I ended up going with a floor shift due to the tranny linkage being 'backwards' (I now realize TCI sells a piece so that this linkage problem doesn't occur anymore)
As for headers, I don't recall what I used..local guy gave them to me since he gave up on his 77. I had to notch the crossmember for them, other than that no issues.
Radiator was the stock 302 w/AC radiator with a lincoln OEM clutch fan. I carved up and fiberglassed the fan shroud to fit.
On an 85 degree day, the truck doesn't get past the first line of the letter "N" in normal.
Old Jun 29, 2007 | 09:24 PM
trinogt's Avatar
trinogt
Ventless windows would be cool... As usual, the aftermarket has the glass kits for old chebbies, but I have yet to see them for Fords. Still gotta have vent windows.
I would like to know about these 'straps' for power windows too.
I have always wanted the DJM dream beams. Hope to do it some day soon!
