460 Timing
Old Jun 25, 2007 | 12:39 PM
Voh's Avatar
Voh
460 Timing
I Ask Thins Once Before, But Need To Ask It Again. I Have The The Whole Truck Back Together, The 460 Swap Went Well, And The Exhaust Sounds Good. The Motor Is A '73 Which I Installed A '70 Timing Chain Into After Some Recommendations Forom Peoples On Here. It Starts Well And Sounds Strong, But It Will Not Let Me Open The Choke All The Way (manual Choke). It Really Wants That Extra Gas At Idle. As It Sits, Im Idling @ About 15-1600 In Park, Seemed To Be Right For The Warmup. I Had Meesed With The Timing A Bit Before The Pipes Where On, And Looking At It Yesterday, I Would Sat That Its About 15-12 Btdc. Any Thoughts As To Why She Wont Idle? Is The Timing Too Advanced, What Should It Be?
Should I Turn The Idle Up So That It Idles Without The Choke And Go From There?
Old Jun 25, 2007 | 08:01 PM
hotrodmerc's Avatar
hotrodmerc
What is the timing totaling at?? You are right you need to get it idling before you can do any further tuning.
Old Jun 25, 2007 | 08:38 PM
Voh's Avatar
Voh
what do you mean by totaling? looking at in reference to TDC, i would say that i am around 10-12 deg BTDC.
Old Jun 25, 2007 | 09:58 PM
Bear 45/70's Avatar
Bear 45/70
Carb, turn the idle mixture screws out.
Old Jun 26, 2007 | 03:03 PM
hotrodmerc's Avatar
hotrodmerc
Do you have a timing light with an advance **** on the back?
rustyranger390
Sep 17, 2011 02:50 PM
1954F250
Sep 4, 2008 11:11 AM
86rustbucket
Mar 13, 2008 06:41 PM
nsshull
Feb 12, 2008 12:49 AM
littlefoot
Jan 18, 2004 12:11 PM
