Fpr
Old Jun 25, 2007 | 09:50 AM
countrystrokin''s Avatar
countrystrokin'
Question Fpr
How much if any , Do you gain by shiming the FPR ? Do you do it for power or mileage ?
Old Jun 25, 2007 | 10:14 AM
FN74's Avatar
FN74
Typically people see about 5-10 psi when shimming. Depends on the shim size used. This is primarily to help force more fuel into the heads, which will help promote better injector filling in the less than ideal deadhead fuel system, mostly #8 injector. The only way to get more fuel past a given point is to make the restriction larger, or add more pressure. There are a few other better ways of attacking this, but that is the cheapest. The better alternative is either a full on Regulated Return or the CCK.
Old Jun 25, 2007 | 10:41 AM
F250_'s Avatar
F250_
So, Jason, with the CCK in place, is there nothing to be gained by shimming the FPR?
