hello all, i was wondering if parts for normal bronc will fit in a centurion? to be honest i never knew there was a 4door bronc, i was gonna graft 2 together on a wreaked excsurson frame(if i could find one) but if i can can get one done w/ a diesel and solid front then im getting one but i need to know if i need parts can i get em from Discount or Bronco Grave Yard, or even a normal junk yard? or do i need to speacial order them?
About the only part of a Centruion that is Bronco related is the removable cap and tailgate. Everything else is from the donor truck chassis (F-_50). If all else fails, the VIN should tell you what kind of truck the donor was.
There is 3 on eBay right now. You will have a really hard time because they made so few.
In other words you will not find many of these sitting around. Keep a eye on ebay . The one from PA isn't bad and there is onother that was a fixer upper. If you want the frame get one done or cut up a F350 frame.
But from rear doors frontward its a crew cab and back its a bronco .
Good luck I want the 94-95 F150 centurion crew cab . Need to haul light things so a F350 isn't needed.
