20 Mpg!
Old Jun 24, 2007 | 10:26 PM
NS F250's Avatar
NS F250
Talking 20 Mpg!
Well, it's a new record.......for me. I just got back from a trip to Eagle River, WI, maybe 230 miles one way from my house. On the way up, I stopped for fuel and was shocked when the milage calculated to over 20 mpg. The trip was mostly 65 mph with maybe 50 miles at 75 mph. I was not trying to get the best economy possible, I mean there were a couple of full throttle passes in there and I did not try to keep it under 2000rpm when accelerating. This truck is not new to me, I bought it brand new in Oct of '01 and the best I have ever seen was 18 mpg. I added the 203* stat and 6637 filter not to long ago, this is the only thing different in the last 5+ years. I would say that one or both of these things are responsible. Btw, I thought it might be a fluke, so I checked the tank on the way home and I was even more freaked when I hand calculated it to 21.5mpg.
Old Jun 24, 2007 | 10:31 PM
clux's Avatar
clux
I've had several different air filters, but never noticed a difference in fuel economy.
I just recently put in a new waterpump with the 203* thermostat, and am noticing a significant increase in economy as well.
I just wish I had put in the 203* 150,000 miles ago.
Old Jun 24, 2007 | 10:37 PM
NS F250's Avatar
NS F250
I here ya. I needed to fix my leaking stat housing, so I figured I might as well put the stat in as well. Glad I did, I hope I keep seeing these mpg numbers. Looks like my E-350 will be next.
Old Jun 24, 2007 | 10:56 PM
luvemhot's Avatar
luvemhot
How dose the 203 thermostat give you better mpg? Taking my 5th wheel to on a trip about 1200 miles one way. thermostat cant be that much money or that hard to replace. if i can pick up a 1/2 a mile it would save a buck or two
what do ya think
Keith
Old Jun 24, 2007 | 10:59 PM
John311t's Avatar
John311t
trust me they can be hard to replace. diesel site had the tstat for 30 something bucks.
Old Jun 24, 2007 | 11:00 PM
Tenn01PSD350's Avatar
Tenn01PSD350
All I can say is hmmmm. It is hot here. I am happy to see those #s though. I may try the 203.
Old Jun 24, 2007 | 11:03 PM
empiretc's Avatar
empiretc
sounds like a good idea. maybe its worth a shot. gotta be cheaper than the blue cps i was suckered into. i finally traded it off (it was riding as a spare) for the new gray one.
Old Jun 24, 2007 | 11:05 PM
clux's Avatar
clux
what do ya think
Keith
You may not see the benefit pulling a trailer where the engine is hotter anyway. With the stock thermostat my engine ran consistently right around 180* empty (not pulling a trailer)regardless of the ambient temperature. With the 203* the gauge sets at just above 200*. Apparently, my engine is more fuel efficient at the higher temperature.
Old Jun 24, 2007 | 11:07 PM
John311t's Avatar
John311t
We will see what my mileage unfolds. The wierd part is that i didnt replace anything for mileage as it just needed replacing. The ebps replacement is showing better mileage, so we will see what the 203 comes up with.
luvemhot's Avatar
luvemhot
Is the thermostat located where the top rad hose gose into the block?
thanks
Keith
Old Jun 24, 2007 | 11:08 PM
clux's Avatar
clux
thanks
Keith
yes, it is.
Old Jun 24, 2007 | 11:17 PM
luvemhot's Avatar
luvemhot
thanks
Keith
Old Jun 24, 2007 | 11:35 PM
powerstroked162's Avatar
powerstroked162
Congrats on the 20mpg.
Cowboy Steve
Old Jun 25, 2007 | 08:43 AM
NS F250's Avatar
NS F250
I want to be clear that I am not claiming that any particular part is what is responsible for my fuel economy. I have never takin this particular route before I changed the stat, so I don't know exactly what my mpg would be stock. What I do know is I have never got this kind of mileage before. I changed the stat because I was in there replacing the stat housing anyway, so I figured why not. FYI, my truck only has 45,000 miles on it, so I doubt I have any of the mileage robbing problems some of you may have. My work truck is a 03 E350 PSD, and lately the best I get out of that is 15 or 16 mpg. The van weighs about the same as my truck (around 8,000#s), but it has 125,000 miles on it. My advice would be to change the thermostat if you want, but
I don't know if I would bank on huge mileage gains.
Old Jun 25, 2007 | 08:49 AM
nlemerise's Avatar
nlemerise
Can you share the dtails of where you started from and what route you took?
