Reminds me of an old movie, "Christine" was the name I believe. Old Chrysler or was it Plymouth Fury? I've often thought of naming my truck Christine. Of course some of you folks have it worse than I do.
My co-workers nicknamed my rig 'Christine' shortly after it's purchase after I had a dozen or so intances where shutting off the cruise control with the 'OFF' button while braking caused the throttle to pin wide open and the truck would just take off. The only way to stop it was to shut it off. After 4 or so months the dealer finally replaced nearly everything PCM, ECU, Cruise circuit, and they expelled the demon. Thought you all'd get a kick out of that.
Maybe im wrong, but the TC lockin up is PCM controlled, wouldnt that have something to do with the tuning, and not the trans?
my DP tuner is set for the BTS..this locale Trans shop was suppose to run a test to let me know what was wrong with my Trans..it would shift fine but tc would not lock up some times...other times it locked up good..I thought it was the tc solenoid..turned out to be a blown tc..so he went ahead and rebuilt me a Trans for $3300 and he used the sonnax kit and used a $800 tc he got some place..I'm pissed..he was never asked to rebuild it I was going to get a bts Trans..so now we are off to court..
ok guy's brain tease for ya..I got some 1156 green LED'S..make the head lights more greener in brighter sun light..I got some sockets from an old bronco of mine..but they are too tall and the hood hits the sockets when I try to close it..I need to find a flatter style plug..one that comes out of lens and takes a 90* turn..any one know of a car with that kind of plug???..maybe I need to up grade to the flat style push in 1156 bulb??like the 194.. thanks
