Sponsored by: Real Truck
Trailer towing
Old Jun 24, 2007 | 07:37 AM
caleb's Avatar
caleb
Trailer towing
I may be purchasing a new F250 V10 this week but have a camping trip planned a week later. Is there a any problem towing a 8000 pound 5th wheel with a brand new truck right away or do I first need a break in period? Does anyone know?
Old Jun 24, 2007 | 08:10 AM
Feralhog's Avatar
Feralhog
There's a break-in period. I got mine and drove all over hell and back just to get the minimum miles on it as I had a camping trip coming up also. I think it is 500 miles or was for the 2005 model. Ask the dealer.
Old Jun 24, 2007 | 11:17 AM
Ricohman's Avatar
Ricohman
You need a few heat cycles through the diffs before you can really work them.
It wouldn't hurt to put some miles on the motor before working it either.
Old Jun 24, 2007 | 12:06 PM
caleb's Avatar
caleb
What are heat cycles? How many miles do you think I should put on it before I tow?
Old Jun 24, 2007 | 12:10 PM
rbaker6336's Avatar
rbaker6336
hook up and go if it's gonna break don't matter if you wait 20k mi if it would break it will still break
Old Jun 24, 2007 | 01:45 PM
Beerstalker's Avatar
Beerstalker
My 07 said not to tow for the first 500 miles as well. I have to believe Ford puts this in there for a reason. My guess is to break in the gears as saskdiesel said. I believe gear manufacturers recommend the same thing when you install new gears don't they?
Old Jun 24, 2007 | 01:51 PM
rbaker6336's Avatar
rbaker6336
haven't played with baby gears for a while
ones I done went in this order
1 install gears
2 get load skip this if already loaded
3 hit the road
Old Jun 24, 2007 | 02:04 PM
Feralhog's Avatar
Feralhog
Well.....do what you have to do but I wouldn't tell Ford you drove it home, hooked up the 8000# trailer, and drove off on a camping trip when you bring it in to have something repaired.
Might be even worse if you're calling Ford to come get you and the travel trailer is hooked up and you've got 100 miles on the odometer.
It would probably do fine but for me, when spending that kind of money on something I tend to follow manufacturer's recommendations. Then again, I'm not a mechanic so I'm relying on the shop to repair my vehicles.
Old Jun 25, 2007 | 10:14 AM
edjunior's Avatar
edjunior
I would tend to agree with the break in. I've heard some do, and some don't, but if it's brand new, and that much money, I'd rather be safe than sorry. Besides, you have a great excuse to get out and just enjoy the drive. Hit some good hills and lots of stop and go traffic to get everything a good workout.
Old Jun 25, 2007 | 11:45 AM
scsmith42's Avatar
scsmith42
Like previous posters, I would also recommend allowing adequate time for the components to break in before towing.
There is typically a lot of heat generated during the break-in process, as the different components are wearing in together and the friction levels are higher. The risk you run when towing before break-in is that the loads will create excessive heat, and the lubricant will break down or otherwise not cool.
The bottom line is that you can create premature wear that will come back later to haunt you.
You don't need to totally baby the vehicle during break-in, just vary the speeds and loads and allow the components to cool between break-in trips.
Old Jun 25, 2007 | 01:08 PM
enjoythetrack's Avatar
enjoythetrack
Agreed. Vary the speed and load. ALWAYS start out gentle upon startup and wait until your fluids/engine/tranny are warm and happy (usually 10 to 15 minutes from start up) and THEN a regiment of getting harder on things to less hard to hard again, to less hard (wash, rinse, repeat) and be sure to vary the RPM and gears accordingly.
Also, usually around 3k miles from band new i have the dealer flush the oil AND ALSO tranny fluid. During break in there are particles that build up as the parts initially get 'married.' While some of these particles are held in suspension within the oils, my feelings are to fully flush these fluids early to remove said particles, as this can have the added benefit of extending the life of the components. Most people, sadly, never flush the tranny fluid at first 3k.
Old Jun 25, 2007 | 01:12 PM
mike415's Avatar
mike415
I had my 04 250 V10, one day before towing the 5er, about 8000 lbs, took my time up Ute Pass, and didn't use overdrive, seems to work fine for me, no problems at all.
