transmission diode
Old Jun 21, 2007 | 11:11 PM
bigtorque's Avatar
bigtorque
transmission diode
alrighty, my buddy 01 350 tranny over heating, would it have the diode, if so or if not, what does the diode do and where is it.
Old Jun 22, 2007 | 11:11 PM
aklim's Avatar
aklim
Dunno. The diode is IN the trans. You won't know till you tear it apart. Below is some reading. When my diode locked up, it felt like someone had hit the E-brake and it won't go past 2nd gear. Also 2 mins after it happened, trans fluid is black and burnt.
The 2001 Models built for August 2000 to March 2001 are the ones with a mechanical diode, all other models have a 34 element sprag from the factory. All Monster Boxes, irregardless of year are built with the 45 element sprag assembly. A mechanical diode is one form of a one way clutch. When the E4OD came out in 1989, it had a sprag one way clutch on the top of the direct drum, and it worked great for 12 years. So Ford in 2001 changed it to the mechanical diode, which didn't work great and after literally 8 days, they realized it was not going to work. The only problem was that all the tooling for the original sprag was destroyed already and it took Ford 6 months to get new machines to go back to the way that they always were. The units built during those 6 months are the diode units. The diode has a different clutch plate pattern, different direct drum and an integral race. To replace one with a sprag, you need to replace all these parts.
Old Jun 22, 2007 | 11:44 PM
bigtorque's Avatar
bigtorque
thanks aklim, hummm, doesnt sound like it would cause speratic over heating issues, just go bad and roast the tranny. but thanks, the dates are helpful.
Old Jun 23, 2007 | 06:43 AM
aklim's Avatar
aklim
Give BTS a call and talk to them. Maybe they have some better insight.
Old Jun 23, 2007 | 06:48 AM
Uzumati's Avatar
Uzumati
Sporadic overheating can sometimes be caused by the bypass sticking or a restriction in the lines to the cooler causing the line pressure to rise and the fluid to use the bypass
Old Jun 23, 2007 | 11:20 AM
bigtorque's Avatar
bigtorque
the bypass valve would have been my guess, and still may be, though he just had it replaced about 6 months ago because it stuck closed and overheated, he then told me there was a TSB out for his particular year and ford replaced it under his extended warranty.
pchristman
Electrical Systems/Wiring
Jan 12, 2020 03:51 PM
MauleOne
Jul 24, 2013 10:38 AM
throwdown
24
Apr 5, 2009 08:42 AM
61 uni
33
Jan 3, 2009 09:55 PM
Ken00
1983 - 2012 Ranger & B-Series
Sep 30, 2002 12:18 PM
