I have a 94 F150 supercab 2wd. The truck sits with a slight rake to it and I was wondering if replacing the front springs would make it sit more level. Is there a heavy duty spring available or do I just get the same part #. I just turned 125k. Could my springs be sagging already? I have the 351 with the E4od. I assume new springs would also help with the camber as well.
at 125,000 on a 94 you are going to come up about 3 inches with new stock springs if you need more than that which I doubt then you can get new springs with whatever amount you want. I always replace my customers with Moog standard veritable rate springs they will last you another 150,000 or more miles. about 80 bucks a pair
